Rust at trailing arm mount / top well area
Posted: Tue Feb 16, 2016 12:52 pm
Hi y'all,
I am finally getting to some much-needed work on my Spider, after a long period of neglect due to having a second project car (which I haven't done that much on either), a recently-purchased 911 SC Targa that I can't stop driving (I'd rather drive it than work on other cars) and some other priorities. So I am back on this forum for the first time in a long time with a rust-related question. I do have a more big-picture rust question ("is all this worth fixing?") but I will save that for another post.
My question here is about one specific rust area on my Spider. I have rust-through on the floor-pan surrounding the mounting point for the RHS trailing arm, at the right rear corner of the interior rear floor panel. What I want to know is this:
-is there likely to be any hidden rust in non-exterior sheetmetal inside the unibody?
The reason I consider that there might be is the known history of the car that suggests how the floorpan rust might have happened. I have had this car since about 1990, and in all the years it spent at my family's house in Atlanta, it was parked outdoors under a cover, on a slight side slope with the RHS high. The RHS top well had a habit of collecting water, likely due to a blocked drain tube. We would regularly have to siphon out water that had collected in the plastic well panel. This occurred only on the RHS. It seems likely to me that the rust-through in the floor of the car may have originated with this problem. I won't know until I can remove the top well and nearby interior trim, which I will hopefully be able to do next weekend, when it will be tolerably warm. This rust-through could have happened as a side effect of the water collecting and draining into the body, or it could have happened through more conventional means.
The car has rust in various places on exterior sheetmetal, but only two areas that need attention for safety - this area, and an area next to the trans crossmember mount. Everything else I can live with for years if I want to, except maybe the hole in the tulip panel. While repairing this area by the trailing arm would be pretty straightforward if what I see is all I have to deal with, it could be much more involved if there is interior rust repair needed, and the potential cost might change my cost-benefit calculus for the whole car.
I've attached a couple of photos below. They are the best I could manage with the car on the ground in the garage. I appreciate any feedback that those of you who have burrowed into this area may have.
Edit: how the hell do I post a vieable image link?!? I have this damn problem in one form or another on every forum I try to post images on. Argh!!
David
'81 Spider Turbo
Chicago, IL
David
'81 Spider Turbo
Chicago, IL
