Cast iron turbo manifold from Mark
ORFORD2004
Post by ORFORD2004 »
Did anybody use it or i'm the first one?
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Re: Casr iron turbo manifold from Mark
Post by RoyBatty »
Pictures, or, well, you know....
ORFORD2004
Pictures yes..... but if i can have my car back from the body shop...
I was suppose to have it back April 15...
ORFORD2004
Front view of my new radiator
You can see the change of direction on my water pump because the turbo was in the way
davery
Your car is a: 1985 Spider
Post by davery »
We definitely need a more detailed write up! What turbo are you using? I am looking to go this same route, but am sort of waiting for Mark to come out with a kit (as he said he was). After my tran repair, I may have to follow your path if no kit is available.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
ORFORD2004
Re: Cast iron turbo manifold from Mark
davery
Post by davery »
ORFORD2004 wrote:You better check this out.
http://fiatspider.com/f08/viewtopic.php?f=17&t=23889
So is you had to do it over, would you start with the kit or just buy a la cart?
Don Avery
1985 Pininfarina
2011 Eos
ORFORD2004
I use from the kit: the turbo, wastegate, fuel pressure regulator, turbo timer and the intercooler.
I'm happy with the kit but it was not a direct fit.
davery
Post by davery »
ORFORD2004 wrote:I use from the kit: the turbo, wastegate, fuel pressure regulator, turbo timer and the intercooler.
I am wondering if purchasing the parts separately would be cheaper for me. I am also concerned about this turbo in an 8V engine.
Don Avery
1985 Pininfarina
2011 Eos
ORFORD2004
Probably and I paid like $200 too much...
I have an 8V engine.
davery
Post by davery »
Ah, I misread. I thought you had a 16v engine. I appreciate your posts. They are helping my firm up what I am hoping to do. Probably about a year away, though. This is beyond what I am comfortable with mechanically and will probably sit down with my mechanic this fall to start making decisions. Probably the two things I am concerned about most are the ignition timing control and fuel management.
Don Avery
1985 Pininfarina
2011 Eos
ORFORD2004
Ford Edis4 for timing and Megasquirt to control everything.
If you want a fast Spider, it's the way.
davery
Post by davery »
Sorry to keep asking questions. Which Megasquirt did you use?
Don Avery
1985 Pininfarina
2011 Eos
ORFORD2004
MEGASQUIRT II V3.0
ORFORD2004
The car is running and I put like 800 miles on the odometer. One night he refuse to start in a parking lot. Pump was not running. Call the towing and $50 later the car was in my shop. It was the fuel pump relay that was the problem. $3.50 later the car was running again and because i'm not cheap, I bought another one that I keep in the glovebox. The other problem was a broken stud that hold the driveshaft bearing. I think it's suppose the have rubber in the hole of the bracket but mine are bolts right to the body. The turbo kick in at around 3500RPM and men it pull. In first gear, you don't way to stay there... So you shift. In second and third, the acceleration is scary. The best comparaison i can see is: A little racing go kart but I drive it without helmet and with my dog in the back 8)
If anybody pass near Sherbrooke one day and want to try it, let me know
John
P.S. I adjust my red zone at 6300RPM and I was thinking to adjust it at 6700RPM what do you think about that? At red zone the timing is progressively retard 12 degrees and the fuel pump is cut-off.
Thanks!!!!!!
