Lighting questions?
Posted: Tue Oct 07, 2014 8:45 am
I am in the process of getting the lights on a 73 spider working so I can have the car safety certified.
Side markers. Both front side markers are missing the metal bracket that hold the side marker lights together and secured to the inside of the front fender. The lenses which have threaded studs have been broken off. As a result I found the PO had used some kind of caulking to hold the chrome shell and lenses in place. It has hardened and looks ok from the outside and will hold the wire with the bulb. So no problem for the safety. What is the size of the bulb in the side marker? This winter I will find lenses and the metal bracket restore this patch job!
Rear Lights. Removed lenses by taking out the screws on the back. Some of the plastic hold clips where broken and caulking had been used to secure them in place. Some lenses where cracked. Some bulbs broke off when trying to remove. Noticed some of the wires had been spliced together with tape and one had caulking holding it to the terminal. Removed both units one was badly damaged with a large piece missing. I was fortunate enough to have 2 other pair of rear light assembly units (came in a box with the car) 1 set has a yellow lenses and the original has clear. Not sure why? Cleaned them up and have the parts to put together a pair in good condition. Had to use the wires from one set to replace the spliced wires on another and used different light assembly shells than was originally on the car. I need the lenses gaskets. All of the old gaskets disintegrated during removal and clean up. Can I make these? They seemed to be made from a cork like material. Here is a picture:
Front turn signals. The chrome has flaked off the assembly shell. Suggestions? I will look into chrome wrap.
Front headlights work great
