Page 1 of 1
Minor exhaust leak from catalytic converter flange
Posted: Sun Jun 22, 2014 9:56 am
by rjkoop
Have a minor exhaust leak from the connection from the downpipe to where is connects to the catalytic converter. I'm thinking I'll trying to remove the bolts, clean the surfaces, apply high temp sealant and bolt it back up.
Or does a gasket go there?
Re: Minor exhaust leak from catalytic converter flange
Posted: Sun Jun 22, 2014 10:06 am
by azruss
no gasket
Posted: Sun Jun 22, 2014 10:17 am
by rjkoop
azruss wrote:no gasket
K. So should I use sealant or no sealant and just ensure flatness of surfaces and bolt together?
Posted: Sun Jun 22, 2014 2:08 pm
by azruss
If your surfaces are beat up, then you may have to use a sealant to stop the leaks
Posted: Sun Jun 22, 2014 2:46 pm
by MrJD
No gaskets? Mine dont have gaskets and I planned to buy some...
Posted: Sun Jun 22, 2014 5:49 pm
by redcars
Nope no gaskets. I used RTV copper on mine and I have no leaks. I made new end plates and welded a 2" exhaust pipe to them to replace the cat.
Posted: Mon Jun 23, 2014 9:19 am
by WYSpider
redcars wrote:Nope no gaskets. I used RTV copper on mine and I have no leaks. I made new end plates and welded a 2" exhaust pipe to them to replace the cat.
+1 on RTV Copper and no leaks.
Posted: Mon Jun 23, 2014 9:22 am
by rjkoop
K. RTV copper it is!
Posted: Tue Apr 21, 2015 4:23 pm
by rjkoop
Looking at this issue again. How easy it is to remove the nuts/bolts that hold the catalytic converter on? I've sprayed with penetrating oil but they seems rather rusted on. And it looks like the nuts are on the inside of the converter.
Do I loosen from the outside...
... or from the inside...
Looks impossible to get a wrench if I need to loosen from the inside. Maybe you need to bend the flange of the catalytic converter out of the way to get a wrench on those bolts?
I just want to fix the leak and not have a hugely expensive exhaust repair.
Posted: Tue Apr 21, 2015 5:20 pm
by 4uall
being that we do not require e tests for our cars I had mine removed and had a straight pipe put in to the muffler
Had the guys at Midas in Bells Corners do it with zero issues since May 2012
Posted: Tue Apr 21, 2015 7:53 pm
by rjkoop
So confirmed that the exhaust leak was coming out of the cat.
So I think a straight pipe is in order (no emissions for these older vehicles here). Looks like I don't have a resonator. Here's a few pics.
Seems to be only exhaust header, down pipe, cat, pipe up and then muffer on back.
Thinking about cutting the pipe just before the cat (cut the bolt out too - what's that for anyways?) and just before it starts to turn up. That's the only major rusty section anyways. Is this a job I can do myself without a torch to cut? I'm thinking a straight pipe, pipe hanger where the cat is now and then a flex pipe for the final section. Or maybe a muffler shop wouldn't charge much for this?
Posted: Wed Apr 22, 2015 12:22 am
by DieselSpider
The bolt prior to the CAT on the older cars is usually a plug for inserting an exhaust gas analyzer probe for reading fuel ratios because you will get false readings if you take them after the CAT has done its thing such as at the tail pipe. I still have my 1970's exhaust gas analyzer however the lambda probes and computers on the new cars make it mostly obsolete.
Posted: Wed Apr 22, 2015 8:13 am
by Nanonevol
I'm piecing together an exhaust system including a 3 bolt "cat delete" or "test pipe". I bought 2 gaskets with a silver foil appearance. Call me dense but I need to hear it again...I would do better to assemble without these and use some RTV copper? (apology for the thread hi-jack).
