Turn signal assembly
- 70spider
- Your car is a: 1970 Fiat spider
Hello, I can't get my turn signals to work, I replaced the flasher and dremeled the tailight connections and still no turn signal. My next move is to have an automotive electrician take a look. I might have to replace the turn signal switch assembly but I can not find one for the 1970, however, I found a 1973 NOS at Midwest-Bayless so I was wonder if I can not locate a '70, can I somehow make the '73 work?
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
- 70spider
Re: Turn signal assembly
Update:
I just did a check. My wipers now work
, must be the new fuses, and my low and high beam switch works so what could be wrong with the turn signals? New flasher and bulbs (don't know if they are correct kind but they fit) could it be a ground?
If so where are they located? I am an idiot when it comes to reading an electrical diagram, dispite the fact I had to draft them in 8th grade
, off course that was 35 years ago
I will also tell you the bulbs in my '70 are not the same as the factory specs. Factory specs call for dual filament bulb however all the sockets are for a single filament bulb (they only have one contact) the mystery continues.
Well any advice would be great.
Pesto
Pesto
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
Does your car have an emergency Hazard light switch?? If it does so they work?
- azruss
If you bought a flasher unit from the autoparts store and just matched up the blade pattern then it is wrong. Those units fit the plug, but each blade does not serve the same purpose. you can make it work by switching 2 of the 3 wires. dont remember which ones. I would recommend getting one that is truly a fiat part.
- 70spider
I got the flasher relay from AutoRicambi. I had to fit the wires with the new slip-on connector instead of the screw on type (absolutly the hardest job I ever did, being 6', 200lbs, and old is not ideal for working on the wireing). I put the blue wire on the "P" terminal and the violet wire to the "L" terminal per the wireing diagram. The third which in my car was green (not white/black as the wireing diagram indicates) to the "X" . The old flasher had no indication marks on which terminal was which. I'll try switcing them and see what happens.
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
- Your car is a: 79 spider
you can borrow the switch assembly, a hazard switch, and a hazard relay that was in the 70 i had if you want to use them to rule stuff out....
- 70spider
Thanks for the offer, but I bought a e-switch and flasher from a fellow forum member.
So I hope the problem will be solved next weekend.
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
