Page 1 of 1
ITS ALIVE!!!!
Posted: Sat Feb 18, 2012 9:23 pm
by Gopher
Finally got my 1974 spider fired up and running. Thanks Mark / Greg at Allison for having that distributorless ignition system, was pretty simple to install.
Didn't have it running long because of not having any coolant in it...that's tomorrows project...then a quick trip up and down the street to test brakes and transmission.
Re: ITS ALIVE!!!!
Posted: Sat Feb 18, 2012 11:14 pm
by wachuko
What a great feeling!! Good for you!! Keep us posted on the progress
Re: ITS ALIVE!!!!
Posted: Wed Feb 22, 2012 12:46 pm
by Gopher
Well, finally got her to start and took a two minute trip in car realized NONE of the gauges were working including oil pressure, so (project creep) motor and trans are coming out. Also have a coolant leak from somewhere that isnt the radiator ( which needs redone.) Was going to do rolling resto, but i guess not. Finally got her in the air and she is leaking from just about every gasket i can identify besides intake or carb as well. Only bad rust i found was passenger side surrounding seat rail, of course i havent scraped out the under layment yet to look at bare metal either.
Re: ITS ALIVE!!!!
Posted: Wed Feb 22, 2012 6:47 pm
by 124JOE
Gopher wrote:Well, finally got her to start and took a two minute trip in car realized NONE of the gauges were working including oil pressure, so (project creep) motor and trans are coming out. Also have a coolant leak from somewhere that isnt the radiator ( which needs redone.) Was going to do rolling resto, but i guess not. Finally got her in the air and she is leaking from just about every gasket i can identify besides intake or carb as well. Only bad rust i found was passenger side surrounding seat rail, of course i havent scraped out the under layment yet to look at bare metal either.
after sitting for awhile these car dry out everywhere
i had mine sit and the carb gaskets dryed out
it spit gas all over after the first run around the block
i let it sit fir an hour.the gaskets sweled and didnt leak after that
i didnt tighten any thing ether
its like it fixed its self
