Page 7 of 55
Re: Edit... Resto mod coming together
Posted: Fri May 09, 2014 1:40 pm
by SoFlaFiat
I was a boat builder in another life so I have no worries making fiberglass panels for the kick spaces. I am still going around in circles with speaker location. That said, a good stereo is not my priority since I like the sound of these cars so much.
Posted: Fri May 09, 2014 8:35 pm
by toplessexpat
There's sound, and then there's SOUND
Posted: Sat May 10, 2014 6:20 am
by SoFlaFiat
I can't wait to hear that SOUND from this one!!
Posted: Sat May 10, 2014 6:34 am
by SoFlaFiat
Relay block gone... Still a bit of tidying up with the wiring but back together and yes, cleaner!!
Posted: Sat May 10, 2014 9:23 am
by SoFlaFiat
Talk about baby steps...
Every time I test and sort a connection, get it labled and set aside, I have a little mental celebration!!
Posted: Sat May 10, 2014 5:54 pm
by toplessexpat
But you'll know that they're done right!
.... now about those plastic horns....
Posted: Sat May 10, 2014 9:30 pm
by SoFlaFiat
Ha, those plastic horns are gonna have to do for a bit!
I finished buttoning up my relay bank, with a dedicated fuse panel.
And tested all the headlights again
Posted: Sun May 11, 2014 12:31 am
by vandor
Nice!
Posted: Sun May 11, 2014 7:06 am
by SoFlaFiat
Thanks Csaba!! Couldn't do it with out you guys!!
Here's a shot from last night with my footwell flood lights up and working.
Posted: Sun May 11, 2014 8:57 am
by toplessexpat
Nice!
Darn it - I'm going to have to do more stuff to mine now.....
Posted: Sun May 11, 2014 3:56 pm
by SoFlaFiat
Which one Andy?
Ok, have to quit early today to prep for the mom but I did get my steering column wiring completely sorted. Everything tested and working as it should with the exception of the intermittent wipers. I'm just going with a two speed set up.
Happy Mother's Day to all the moms!!!
Posted: Sun May 11, 2014 10:26 pm
by toplessexpat
The 1800 - still not got the 2000....
Time to wire up the footwell lights I purchased ages ago!
Posted: Mon May 12, 2014 12:47 am
by vandor
With some of the column switched the intermittent relay does not work. There is one wire that is reversed on some switches, when it should be grounded it's not and vice versa. I was able to fix this on a friend's car by cutting one of the wires going to the column switch and grounding them. Problem is I forgot which one...
Posted: Mon May 12, 2014 6:01 am
by SoFlaFiat
Csaba, I've tied off the yellow and white wires that Brad's diagram show going to the intermittent switch and run a low and high power to the cowl. I haven't pulled a wiper motor yet to test it but this should work right?
I do have one wire coming out of the steering column that I couldn't find any use for and couldn't find on any of the wiring diagrams. It is black with a purple stripe. Anyone know what that one was meant to do?
Posted: Mon May 12, 2014 7:02 am
by fiat218
Did you make the harness before you install ?or do you pull wires one by one to make it
