Page 4 of 14
Re: My 1967 Fiat 124 Spider Restoration Journey
Posted: Wed Mar 19, 2014 9:26 pm
by Mick124
I am glad to see you got to the end... What a major undertaking..
I will be replacing all the front inner panels, shock towers and chassis rails. Managed to find complete sets
Posted: Thu Mar 20, 2014 1:55 pm
by djape1977
i have used inner fenders, chasis rails and shock towers for sedan so i had to fabricate upper portion that's diferent to spider.
just be carefull when putting new rails in, it's critical to measure everything more than once.
use these measures, they are the same, apart from ride height and lenght between axles
Posted: Thu Mar 20, 2014 3:10 pm
by BEEK
Posted: Thu Mar 20, 2014 7:08 pm
by crazymoose1990
I'm a noob when it comes to Fiat's and uni-bodys for that matter. Sorry to interrupt this great thread, I'm also restoring a Fiat 124 Spider I found out mine had been in a crash, yeah the uni-body I think was straightened. But I'm pulling the front fenders off of our car, I figured that part out. I am however having problems with the rear quarter on the drivers side as it will need to be replaced....... The part I'm trying to figure out is how to drill the spot welds out on the top of the quarter between the trunk lid and the area behind the back seat. I have two Fiats one we bought as a running driving rust free California car. Our 69 has rust issues, Probably not really all that bad, but I would rather fix the bent frame rails on the California car than cut out rust on the 69... Also how does the inner fender apron get replaced doesn't that metal get sandwiched in behind the firewall?
Oh and how do you get to the spot welds in the valance area, oh Jeeeeez am I in over my head!!!!! I have so many questions!!!!
Thanks in advance, sorry for the dumb noob questions.
Posted: Thu Mar 20, 2014 9:20 pm
by Mick124
Thanks guys,
I have those and have already passed them on to the panel beater. He ha purposely build the car from jig to ensure measurement are to the millimetre.
Thanks again. Appreciate the support and responses.
Mick
Posted: Thu Mar 20, 2014 9:31 pm
by crazymoose1990
So can anyone answer these questions?
Posted: Thu Mar 20, 2014 10:52 pm
by BEEK
some of the spot welds are not possible to get to. ask me how i know
but you have to decide what piece to remove and how it was assembled, take apart in reverse order, i use a air chisel, to break the spot welds i cannot get to to drill, yes it damages something, so i try and damage the panel im removing if i am replacing it with another, if i can cut a section out of the old panel and drill the welds i will do that, but if you are trying to remove and reuse the same panel on the same car, then take your time. and do your best not to damage it much, but you will end up with a repair area somewhere
Posted: Fri Mar 21, 2014 3:53 am
by cos
crazymoose1990 wrote:I'm a noob when it comes to Fiat's and uni-bodys for that matter. Sorry to interrupt this great thread, I'm also restoring a Fiat 124 Spider I found out mine had been in a crash, yeah the uni-body I think was straightened. But I'm pulling the front fenders off of our car, I figured that part out. I am however having problems with the rear quarter on the drivers side as it will need to be replaced....... The part I'm trying to figure out is how to drill the spot welds out on the top of the quarter between the trunk lid and the area behind the back seat. I have two Fiats one we bought as a running driving rust free California car. Our 69 has rust issues, Probably not really all that bad, but I would rather fix the bent frame rails on the California car than cut out rust on the 69... Also how does the inner fender apron get replaced doesn't that metal get sandwiched in behind the firewall?
hi, i replaced both rear quarters. First i drilled out all the spot welds that are visible, but regards the area in question where the rear wing or fender meets the rear panel i used a grinder and removed sections of the fender to give me access to the lip and to the spot welds.
Posted: Fri Mar 21, 2014 4:53 am
by Mick124
Posted: Fri Mar 21, 2014 2:00 pm
by djape1977
Posted: Fri Mar 21, 2014 4:07 pm
by Mick124
Car body is secured on a customised jig. We have all measurements and a new crossmember. I really appreciate your pictures and your comments. Keep them coming. Have you finished car.
Posted: Sat Mar 22, 2014 4:22 pm
by djape1977
not yet. by the way you're going, it's likel you'll overtake me. currently, i'm in the stage of final panel beating before first filler is applyed. i'm trying to straighten out every dent i can find, no matter how small it is. also, the panel gaps are horrific, and what i can see on pictures of other 124 spiders, it's how they came from factory. i'm trying to make them small as possible.
engine is done, full rebuild, gearbox too, new rear axle, rustproofing done, new brake lines, new fuel lines, rebuilt front and rear suspension...
Posted: Sun Aug 10, 2014 6:39 am
by Mick124
Posted: Sun Aug 10, 2014 8:48 am
by SoFlaFiat
Wow! What a project!! Amazing work!! I can tell already that this is going to be a beautiful car!!
Posted: Mon Aug 25, 2014 7:18 pm
by Mick124
