Antonia Part 18: Like the Flinstones!
Posted: Fri Aug 24, 2012 7:00 pm
Well, this will be the last post needed in order to bring this thread up to date!
I have started in on the floorboards now. Focusing on the rust holes and trying to get rid of any dangerous areas.
Beginning with a wire wheel and grinder, I cleaned the surfaces as much as possible, then vacuumed and wiped everything down with solvent to prep for surface treatment. For this I have two compounds, one is Naval Jelly and the other is by Permatex:
Both are effective, but they work differently. Naval Jelly is designed to dissolve the rust, then get wiped off. The Permatex actually converts the rusty surface to a hard, paintable surface. I used this for the floorboards, simply painting it on.
The rusty, pitted surface ends up looking something like this:
Not perfect, but the rust is stopped.
Next I started cutting out large sections in simple shapes. We use a lot of sheet metal at work, so I was fortunate enough to get some scrap pieces cut to size which I could just drop in. All I had to do was make sure the hole was the right size and weld it in.
Looks like I'm Fred, searching for my Wilma!
I began welding in a piece where the fuel lines had rotted the floor.
It is not easy welding such thin metal, but it should look okay once I grind the welds down. I will probably use a seam of body filler to make smooth transitions. I will need to put in some metal on the seat mount yet, but I am currently out of MIG wire!
