Page 4 of 31
Re: 1981 Fiat Spider 2000 - What am I doing!? LOL!!
Posted: Sat Sep 10, 2011 9:34 am
by jimmycakes401
Ohhhhhh. Did some of them not come with them? Or did your's rot out? Have you thought about just making a set? I'd imagine bungie chords would work. Or you could go to home depot or a supplier to get giant springs. I can measure these for you.
Posted: Sat Sep 10, 2011 10:19 am
by 124JOE
no my 78 dosent have the holes and hooks for them
they gave me a rod witha spring,that i pull down and the lid stands on it.
and the spring pulls the rod leg back tward the center for closing the lid.joe
i guess im good
Posted: Sat Sep 10, 2011 11:57 am
by Kingme2
124JOE wrote:jimmycakes401 wrote:Any hose masters out there? I know one of them is 8mm. LOL!
sizes i dont know
2/3/4 appear to be vacume hoses.
5/7 is brake hose
6 is a fuel line
i think .joe
awesome... I've wanted to replace my Uglies with something nicer, now I have a start on type (just have to measure for sizes...unless someone knows?)
Posted: Sat Sep 10, 2011 9:20 pm
by jimmycakes401
4 & 2 are 12mm I believe
Posted: Sat Sep 10, 2011 9:21 pm
by jimmycakes401
I linked to 5 & 6 at bayless.
by jimmycakes401
I believe 3 is 4mm
Posted: Sun Sep 11, 2011 9:34 am
by 124JOE
#6 is 8mm-5/16 fuel line
#5 #7 are hydrolic line 8mm i think.joe
Posted: Sun Sep 11, 2011 10:09 am
by jimmycakes401
Oops! You're right. 6 is fuel line. I was thinking it was the other hydraulic hose.
Posted: Mon Sep 12, 2011 7:28 am
by jimmycakes401
Yesterday I sanded down the trunk compartment primed it and then used seam sealer on open joints. Obviously left the drain holes and various screw holes. Today I plan on priming over the sealer and using fiberglass fill for the two large plumbers putty gaps. Next up, I have to make templates because I don't have ANY of the original cards.
Posted: Mon Sep 12, 2011 9:48 pm
by jimmycakes401
Why are there wires in my doors if I don't have power windows?
Posted: Tue Sep 13, 2011 10:19 pm
by Danq
It is easier to make one style of wiring harness that has the wiring for every option than to make a dozen different one and get the proper one in the correct car on the assembly line. There is wiring for radio in the factory harness including power antenna but a radio was a dealer installed option. Wire is cheap compared to the labor to put it in.
Posted: Wed Sep 14, 2011 7:15 am
by jimmycakes401
Okay. Cool. That's what I was hoping. Guess it makes it easier to install power windows if I want later. I've always been a fan of crank.
Posted: Thu Sep 15, 2011 7:40 am
by jimmycakes401
Yesterday I coated my gas tank with rust reform. Tonight I will top coat it. I need to figure out how to hang it up so I can paint the whole thing at once. Or I'll use a nail board. For more info about the build visit
http://fiatspider.weebly.com
Posted: Sat Oct 01, 2011 8:24 pm
by jimmycakes401
Just put up some new info on my blog.
Put the fuel pump in last night. Need to put in the return line. After that's complete I need to do all the welding on the back end. After that I'll fill her up with some gas and see how she runs.
Posted: Sat Oct 22, 2011 8:26 pm
by jimmycakes401
I'm replacing my timing belt and decided to order a new tensioner bearing. I needed to pick up some rubber grommets for my radiator. They seem to be missing. I'm trying to think of any small pieces I may need that I can add to the order. Not a lot of money rattling around, but I want to grab any small bits I can use later. Any suggestions? Check my blog.
