Edit... Resto mod FIRST DRIVE
Re: Edit... Resto mod coming together
I am using Jason Miller's brackets, purchased from AR. They line up beautifully, look great and would be just fine except for the pulley. I visited the machine shop today and he feels confident that we can do a little work on this pulley and it will work.
Beek's idea of moving the brackets, although a good thought, would be very difficult because of the stud location in the block.
I'll revisit that idea if the pulley reengineering doesn't work out.
On the bright side, my gapless rings from TotalSeal showed up today so I can finish building the bottom end this weekend and get the thing on my cart.
I also delivered my wheel adapters, a front hub, and a rim, to the machinist today. He will machine the adapters for hub centric rings.
So, here is the compromise...
We are shaving the rear tab on the lower mount and spacing the alternator forward .25, then spacing the pulley forward on the shaft .25. This will get me right where I need to be. Everything is at the machine shop getting sorted so I went back to building the bottom end.
I got the rings and bearings all organized and on the pistons and into the block
Torqued down my rod bearings and dialed in true TDC
And marked my crank pulley.
Everything rolls over very smoothly so I am pleased.
I moved on to oil pump, breather tube and oil pan.
Tomorrow I hope to get it bolted up to the transmission.
Wow, nice looking, your making me jealous
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
All rusty scrappy jokes aside Jim, I highly doubt you will be jealous of anyone once Beek gets your motor done!
I'm always jealous, you guys are here do very good workSoFlaFiat wrote:All rusty scrappy jokes aside Jim, I highly doubt you will be jealous of anyone once Beek gets your motor done!
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Your welcome, when I go to Florida again, I will be at your door, better yet your garage.SoFlaFiat wrote:Thanks Jim! But don't be jealous!
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Wait til winter! It's HOT here now!!
And of course, with any luck I'll have this thing driving by then!
I had a great day getting my engine off the hoist
And mating the trans
Then I got it on the cross member and down on the cart and started installing bits...
Exciting day!!!
Exciting day!!!
- btoran
- Your car is a: 1975 Fiat 124 Sport Spider
- johndemar
Where you hanging from the rafters to get the overhead shot?
Post is way too long to look through, but did you use a lightened flywheel?
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
Thanks B!!
John,
I can't remember if I specified it anyway so no point in rolling back through...
Here's the run down on the build:
Block:
4.5mm dome 84.4 bore pistons
TotalSeal second ring set
Aluminum pulleys
Lightened steel flywheel
Luk clutch set
And of course, new rod and main bearings etc.
Head:
42-82/82-42 cams
43/37.5 stainless valves
All guides, seals etc. upgraded
Isky triple springs
Jason's adjustable all aluminum cam pulleys
Ported by SouthLakeMachine (Beek)
Intake:
Cast aluminum, from Pierce, through AR, with dual weber 44s
Ported for 44s and matched to head by Beek as well
custom cold air intake from lower front valance
Exhaust:
4-2-1 aftermarket (not sure who's as it was on the car) into custom mandrel bent 2 1/2" pipe with magnaflow center muffler and DC rear muffler, both free flow.
Ignition:
95amp alt
Gear reduction starter
Stock electronic ignition with MSD
Magnecor Comp wires
NGK plugs
It all sounds just awesome to me, but I've been dreaming about it for a long time!
John,
Block:
Aluminum pulleys
Luk clutch set
Head:
42-82/82-42 cams
Isky triple springs
Intake:
Exhaust:
Ignition:
95amp alt
Magnecor Comp wires
NGK plugs
U get 44's .then I want them too :$
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Jim, what the hell? The only reason I am going with 44s is because I thought you had them!!!
Nope, but I will now, I damn near have the same built you have, I thinkSoFlaFiat wrote:Jim, what the hell? The only reason I am going with 44s is because I thought you had them!!!![]()
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
