Page 25 of 55
Re: Edit... Resto mod coming together
Posted: Sun Aug 10, 2014 10:25 pm
by toplessexpat
That's because he's taking pictures for our Australian contingent...
Posted: Sun Aug 10, 2014 10:27 pm
by juvius
toplessexpat wrote:That's because he's taking pictures for our Australian contingent...
that has to be it....
Posted: Mon Aug 11, 2014 5:50 am
by SoFlaFiat
"Having friends with the same mental disorder"
PRICELESS!!!
Posted: Mon Aug 11, 2014 10:36 am
by Ptoneill
That's ok wait until he installs the Fallopian tube to the heater core!?........that was a classic for the new guys on the submarine I was on.
Posted: Mon Aug 11, 2014 10:46 am
by juvius
Ptoneill wrote:That's ok wait until he installs the Fallopian tube to the heater core!?........that was a classic for the new guys on the submarine I was on.
on the uss princeton, we liked to send them for an HT punch or a board stretcher
Posted: Mon Aug 11, 2014 10:58 am
by toplessexpat
Following this line.... on the Spider.... we should be recommending that people replace their Rear Guibo then?
A
Posted: Mon Aug 11, 2014 7:41 pm
by SoFlaFiat
Ahhh, you guys are too much!!
Ok, I cut the brackets back off and tested a few new locations. A bit of angle seemed to work best
So I spot welded both sides and tested bottom
And top
No binding within the reach of the shock.
Then just to be sure all is well, a installed the upper arm and checked again
Looks like it will work. Now I have to take it all back out since I am using a spare cross member and my engine assembly needs to be in for final install.
Posted: Mon Aug 11, 2014 8:11 pm
by toplessexpat
Looks like you've got it cracked.... Any room for one of these too?
http://www.ebay.com/itm/281388343671
Posted: Mon Aug 11, 2014 8:33 pm
by SoFlaFiat
If it doesn't block my 3rd brake light... Hell yea, right on the deck lid...NOT
Posted: Mon Aug 11, 2014 8:38 pm
by SoFlaFiat
Tomorrow I will start modifying my rear end to accept a second guibo!!!
Posted: Mon Aug 11, 2014 9:24 pm
by fiat218
SoFlaFiat wrote:Tomorrow I will start modifying my rear end to accept a second guibo!!!
Your rear is bad huh,
Posted: Mon Aug 11, 2014 9:59 pm
by toplessexpat
.... it's the future...
Posted: Tue Aug 12, 2014 1:13 am
by stpher
Looks great, can't see in the picture but do you have either tapered washers or spacers on each side of the heim joint. Used to make sure when the joint moves thru it's travel, the ball part of the joint does not hit the through bolt.
Made up similiar for a rear sway bar.
Thanks, Rick
Posted: Tue Aug 12, 2014 5:46 am
by SoFlaFiat
Thanks Rick!
They have tapered spacers.
Here's a better picture
Posted: Tue Aug 12, 2014 2:52 pm
by Ptoneill
Ok, I love the engineering that went into these,,,,they look great, but what makes them different than the bolt on style I used? I can see that they are adjustable but I have no race/suspension design experience. Thanks
