http://www.por15.com/whatispor15.asprontron2012 wrote: what is POR15?
TIPS
Re: TIPS
I looked it up; butane is heavier than air. So we don't need to fill the POR-15 can completely, do we? A butane "barrier layer" will be sufficient?124JOE wrote:... use butane to fill the cans air space so it wont cure in the can
I have portioned it out into baby food jars, but your idea is better.
- giuliot60
- Your car is a: 81 Fiat Turbo removed Spider
Re: TIPS
POR-15 is a rust coating Ron
Giulio/Charlotte
Re: TIPS
Rust treatment, that all I know, look it up and u will get a better understanding, better then I can explainrontron2012 wrote:what is POR15?124JOE wrote:if you used POR15 and you have some left over
also use wax paper to keep the can and lid from sealing together
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 81SPIDERMATT
Re: TIPS
If you do not know something.... ASK.... you are in fact on the greatest site in the known universe
it will save time and much frustration
Re: TIPS
I will 2nd that81SPIDERMATT wrote:If you do not know something.... ASK.... you are in fact on the greatest site in the known universe
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- blurple124
Re: TIPS
When replacing sway bar bushings, you will have some trouble with the inner brackets.
In order to get them apart, you will have to drill the rivets out with a 1/2" drill bit.
To get them back together, put the bushing in place, then put the brackets around it and slip a 1/2" diameter bolt through each side and use them to compress the bracket around the shock. Once fully compressed, tack-weld the brackets together. Remove your bolts and voila!!
I don't have a good trick for the ends yet, but a C clamp seemed to work fairly well
Charlie
1997 Jeep Wrangler TJ Sport
