Page 17 of 55
Re: Edit... Resto mod coming together
Posted: Mon Jul 14, 2014 10:46 pm
by vandor
I will likely be in Pittsburg, so that would be shorter drive!
It was fun, you would have liked it.
Posted: Tue Jul 15, 2014 5:43 am
by toplessexpat
Csaba - that's only an extra 7 hrs each way for us
..... Although jeff and I have a plan........
Posted: Tue Jul 15, 2014 7:12 pm
by SoFlaFiat
Yep, Andy is right, bit further for you but shorter for me. Sounds like a great venue.
All you Texas guys are all set as Andy is footing the bill for a semi next year!
This is the worst time of year for progress on the car since work is crazy busy and it rains sideways pretty much every afternoon so I apologize in advance for the near future lack of posts...
Posted: Tue Jul 15, 2014 7:49 pm
by toplessexpat
Correction "Andy will help look into a semi"!
Posted: Sun Jul 20, 2014 8:51 pm
by SoFlaFiat
I finally made some progress building an engine stand which will allow me to assemble engine and trans with steering rack and exhaust on the cross member. I have to fit everything and build a heat shield between the exhaust and the passengers rack boot. This will also make fitting all the bits very easy and I will jack the whole assembly in from the bottom when complete.
I also disassembled my drive shaft, cleaned up all the parts and painted them this weekend. Good to be making progress again.
Posted: Mon Jul 21, 2014 3:33 am
by cos
impressive!
Posted: Wed Jul 23, 2014 6:58 am
by SoFlaFiat
Thanks Cos!
Getting any decent weather for working on yours?
Posted: Wed Jul 23, 2014 12:02 pm
by cos
SoFlaFiat wrote:Thanks Cos!
yes we are! hitting 32 degrees. So i'm trying to do a catch up. and moaning that is too hot!
Posted: Thu Jul 24, 2014 12:04 pm
by toplessexpat
Alan, as usual this all looks simply wonderful
Posted: Fri Jul 25, 2014 6:20 am
by SoFlaFiat
Thanks Andy!
I have my driveshaft all back together and started fitting my exhaust. The center muffler should arrive today so more soon...
Posted: Fri Jul 25, 2014 6:12 pm
by SoFlaFiat
Still no center muffler but I have been making a little progress with the rest of the exhaust.
Here is the new to old connection,
I will have to trim some of the length off that once I have the center muffler.
I will also have to re-route my emergency brake cable since this pipe is a bit larger than the original.
I think I can make a different bracket and lead the cable over the exhaust.
More baby steps towards hearing this thing roar!!!
Posted: Fri Jul 25, 2014 9:08 pm
by fiat218
are u getting a new header? or clean that one ?
Posted: Fri Jul 25, 2014 11:14 pm
by MadBeez
Man! This is so awesome and inspiring! I hope you post video of the Grand Start-up.
Posted: Sat Jul 26, 2014 6:16 am
by SoFlaFiat
Jim,
This header is in pretty good shape and just needs a bit of clean up. I purchased some internal exhaust coating from Eastwood to help reduce excessive heat.
Madbeez,
Thanks!! I will be playing with my gopro when I get his thing started for sure! There will be an open invitation to the engine install party! I coud use all the help I can get
Posted: Sat Jul 26, 2014 5:43 pm
by SoFlaFiat
With my muffler not here yet (had to reorder) and not enough proper mandrel bent turns to make it work (ordered more of those),I backed off the pipe fitting and got working on a heat shield.
Then I cleaned up and welded the crappy joint in my header and ceramic coated the whole thing. It was something to do...
The header is not new, not perfect, but should work just fine and my budget has gone right out the window so maybe one day...
I'll put it all back on the temporary engine set up tomorrow for a better picture.
