Page 2 of 12
Re: 1981 Restoration
Posted: Mon Aug 01, 2011 9:47 pm
by Divers
Thanks.
Posted: Fri Aug 05, 2011 8:27 pm
by Divers
Body work sucks! Finally got the rust cut out...not "cut" out for this
. Next to weld in some new metal..thenthe fun stuff.
Posted: Tue Aug 16, 2011 8:11 am
by Divers
Well...removed the rocker panels and found some rust at the rear wheel wells. Will all be ground out and rewelded. Getting ready to order parts for IAP, but before I do...looking for some input. This car will not be a street racer, just a nice lazy driver. I have the following to order...if anyone thinks and "upgrade" is worth it, please let me know
1. Wheel bearings for the front
2. New sway bar bushings
3. replacing the 4 control arms (as a unit with new bushings etc etc from IAP)
4. New front rotors (might as well since everything will be off)
5. Will cut the springs (1 coil).
6. Brake pads are like new, so will not be replacing.
7. All the shocks with GR1 and GR2 OEM style.
The rear calipers need replacing, but I will have to wait till next month....funds! I am not going to rebuild mine, just buy some already done.
Posted: Wed Aug 17, 2011 2:53 pm
by Divers
well..since no input, ordered everything on the list. Went with another vendor than IAP. Next few weekends will be busy. Finished using phosphoric acid on all the floors to kill the surface rust. Need to paint the eastwood rust encapsulant this weekend or next.
Posted: Wed Aug 17, 2011 5:43 pm
by 124JOE
yes, your list looks ok.
it sounds like your going to have some fun.
take way to many pics and post some for us please
also pics add documentation to a vehical.its notlike you get a recept for the work.joe
good luck we're all here to help
Posted: Fri Aug 19, 2011 6:46 am
by Divers
An hour to remove the passenger side shock.....shocking! Had to removed the air filter box just to get good access to the top shock bolt...live and learn.
BUT...now that everything is off......someone point me to a TRUE cold air intake? I have searched the posts and really only seen cosmetic replacements for the stock air intake. All of the "cold" intakes seem to just take the warm engine air. The stock system actually seems better from a cold standpoint....just that the damn thing is UGLY!
Posted: Sat Aug 20, 2011 4:24 pm
by Divers
Got my shop manual from spidermanuals today. A very quality product!
Posted: Sat Aug 20, 2011 5:53 pm
by WYSpider
Does it have color illustrations and pullouts? I have been looking for one. Midwest Bayless has one but I think it is $60 + shipping.
Posted: Sat Aug 20, 2011 6:01 pm
by Divers
Some pages are in color. I think I paid $60
Posted: Sat Aug 20, 2011 9:59 pm
by azruss
I replaced my stock FI intake with a K&N style cone filter. I also cut a hole in the radiator bulkhead and mounted a "dryer tube" in the hole so outside air would blow from the grill to the filter space. also thinking of adding a heat shield between the filter and the exhaust manifold.
I did what you are planning with the floor. remove tar, fix rust, paint, install stick-on rubber sound proofing pads. I still havent figured out a carpet underlayment yet.
Posted: Sat Aug 20, 2011 10:09 pm
by Divers
All the tar is gone, then I used phosphoric acid to clean up the rust, then today painted with eastwood rust encapsulate. Also removed the passenger side control arms (that was fun!). Now researching how to clean up and improve the undercoating. Taking things very slow and trying to have fun.
Posted: Sat Aug 20, 2011 10:47 pm
by 124JOE
someone said homedepot has a dynamat style sound deadning stuff and i used home carpet pading 3/8".or i heard of an upolstery shop might have it.i think its called JUTE,joe
Posted: Sun Aug 21, 2011 2:56 am
by DocGraphics
The stuff from home depot is called "protecto wrap", its for sealing around doors & windows in home construction.
It's about 1/16" thick rubber membrane with a white plastic backing & is super sticky, comes in 6" or 9" rolls.
I put it on my floors & about 1-2" up the sides, should be totally waterproof now, I did cut the drain holes back in too.
Don't know how much sound deadening it does but should do some.
Then I put carpet padding I got from yourautotrim.com under my carpet, cover everywhere except tranny hump as the stock stuff was still good & left it in.
http://www.yourautotrim.com/jutecarpetpad.html
They also have the padding with a built in foil/heat top layer
http://www.yourautotrim.com/thercarpad.html
Posted: Sun Aug 21, 2011 7:22 am
by Divers
I bought Eastwood thermocoustic barrier. I am then going to put carpet pad over that like docgraphics.
How many yards of the jute padding did you need?
Posted: Sun Aug 21, 2011 1:56 pm
by DocGraphics
I ordered 4 yards & it was plenty for all the floor boards & I have enough left over that you could do the tranny hump too.
