Warinig and direction lights issue
azambelli758
Your car is a: 1981 FIAT SPIDER
Post by azambelli758 »
Hello,
My name is Alain,
I am a new member living in Normandy region not o fare from Paris, 80 Kms more or less.. and I am very glad to join !
I own a 1981 Fiat 124 Spider US version barn find and on my way to put it back on the road again after several years of lack of tenderness....
A lot of mechanical things have been done on this car
Mechanically sounds pretty well now and I will enjoy to drve it soon !
Still one esxisting issue/pb no warning lights neither indicator lights,. I have changed the flasher by a brend new one but nothing better
I do suspect the Hazard warning switch but still have a doubt.. (fuses and bulbs are Ok )
Did you encounter such kind of failure and do you how to solve it ?
Many thanks in advance for your support !
Have a nice day
BR Alain
rdv
Your car is a: 69 AS Spider
Re: Warinig and direction lights issue
Post by rdv »
Hi Alain,
your welcome! Sorry, that I can't support in your technical question, but have you checked the Electrical groundings (typical problem)?
Interesting story, that you discovered a french barnfind?! But France actually counts 746 Spider in the worldwide Spider Register, see here:
https://www.fiatspider.de/register?Fahr ... All&page=7
Is your car already listed? If not, it would be great to get your car data!
Good luck with your project!
Best Regards Ralf
69 AS Spider
the Worldwide Spider Register
Be part of it and register your car(s). Starting point here:
https://www.fiatspider.de/worldwide-spider-register
wizard124
Post by wizard124 »
From one of my posts:
I mentioned earlier my turn signals and hazards don't work. I removed that center dash panel and found the connector loose from the hazard switch. (another PO poor repair effort...)Once I plugged it back in, the hazards started to flash. :D Nice,, when something broken turns out to be a simple fix! I separated that switch using a linoleum knife. I used some needle nose pliers to bend down the locking lever, cleaned the contacts , and re-assembled it. Fixed
I hope this helps.
wizard124
Post by wizard124 »
Alain,
It sounds like your car is in pretty good driving condition.
viewtopic.php?t=20987
This thread is about my 1980 FI journey.
Warren
