Here's the pad they all had coming out of the factory.
https://autoricambi.us/products/hood-end-pad
I'd have to check mine (which has the pads), but I think they slide into the slots you are seeing in your hood.
Squashed, nearly fixed,...
- aj81spider
Re: Squashed, nearly fixed,...
A.J.
2006 Corvette
2006 Corvette
It did come with pads.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
- Your car is a: 1981 Spider
Yes, they did come with pads but the OE pads were a kind of soft foam. They slide into those corner slots in the hood.
AR's pads are thick rubber and, in my experience, too thick. (I've had words with them about this.) I will end up trimming them down so the hood goes down and does not stick up higher than the fenders.
Goodness,...I don't think I'll install any of these pads!
My hood has always aligned (and does once again) and been trouble-free for 18 years without 'em. I don't fix what isn't broke!
But that sure explains the diagonal slot in the underside of the hood at either rear corner,...
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
- geospider
Todd,
Geo here. Been away in Italy getting married: more about that and the LACK of classic Fiats later.
Lines/gaps look great. wish my hood fit so well.
I have a bunch to update: both with my spider and Italian cars/scooters/drivers/pedestrains in general.
geo
geo
Thanks so much.
CONGRATS! I spent most of my time in the Navy in/around Italy. You need to PM me with some of the details,...where you went, got married, etc,...How cool!
I've spent a number of hours working on those gaps, lines, and panels, too. I'd like to get the Spider looking good enough so that when focodave sees it (prior to our pre-arranged plan to cruise Horsetooth Reservoir together, when completed), he'll have a tough time spotting the repaired spots!
I'm working mostly on scratches now.
Welcome back, and again, congratulations!
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Test fit completed to satisfaction,...
By George, I think we're on our way to primer/paint!
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Can you spot the two different year fenders?
1978, or before, or the passenger's side,...1979, or after, on the driver's side. Can you see the difference?
I had to 'waller out' (lengthen to a slot) the hole that the driver's bumper shock mounts on, to fool your eye,...about 3/8". Now everything aligns pretty good.
Todd.
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
I'd guess that I, and my Spider, are pretty much done with being "Squashed,..."!!
It would be best for my posts to move to the "Restoration Projects" area at this point. I thank all of you for your attention and input,...you've helped to save this Spider from the junkyard. It has some history, so that's important,...
Many thanks,
Todd Compton.
Many thanks,
Todd Compton.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Back,...but in 'Restoration Projects' after a very busy last six weeks, or so,...
My Spider's present appearance:
Got a Superbeetle to finish right now, but I expect to be back onto the Spider's completion before fall,...
I hope this benefits someone, someday,...
Todd.
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
