My 82 spider is suffering from intermittent starting problems. Battery is new, new fuel pump, rebuilt afm. So sometimes it starts on first turn and after it sits for a while I just hear the whirring of the fuel pump but the starter is not engaging. Then if it sits, sometimes it decides it wants to start. I've ruled out voltage drop at battery because it does start at times after sitting and battery voltage seems good. So what should I look at next. I've been reading about relay and brown wire fix and I'm a bit confused. so any help/thoughts would be greatly appreciated. Car runs and idles well when it starts.
Intermittent starting brown wire fix/relay?
- courtenay
Re: Intermittent starting brown wire fix/relay?
See my response in the engine and tuning area.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
1979s and newer had the brown wider fix from the factory.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
- bradartigue
No they had the same issue; it may have even been worse because the newer cars had a connector between the ignition switch and wiring harness.redcars wrote:1979s and newer had the brown wider fix from the factory.
1970 124 Spider
http://www.artigue.com/fiat
are you referring to this brown wire?redcars wrote:1979s and newer had the brown wider fix from the factory.
- RoyBatty
You could have a dead spot in your starter.
