How does this trim come off?
focodave
Post by focodave »
Can someone tell me how to remove this piece of bright trim without destroying the door paint or the trim piece itself?
Looking for advice from someone who has actually done this themselves.
Many thanks:
1970 MGB GT (my other hobby)
76was124
Patron 2019
Patron 2019
Re: How does this trim come off?
Post by 76was124 »
It just pulls up.
I used an ice pick under the edge by the door jamb to get it started, work your way along. A rag underneath and a gentle use of a screwdriver can help prevent bending it as you work it up along its lenght.
A little more detail in this thread http://www.fiatspider.com/f08/viewtopic ... 30&t=30081
Current 81 Spider 2000
Previous 76 Spider
divace73
Post by divace73 »
My One comes off buy lifting it straight up, I use this plastic trim up removal tools, may also wedge a thin plastic sheet (like cut out of an ice cream container??) to further protect the paint work under the tool??
Cheers David
see my >>You tube channel<<
focodave
Post by focodave »
Thanks very much for your prompt responses, guys.
Very helpful....
81SPIDERMATT
Post by 81SPIDERMATT »
mine comes off when you roll up the window .... i would love to know if there is some type of clip that i am missing or do i just need to pinch it a bit so it stays on better .... Matt
laura79
Post by laura79 »
Mine also goes up when i close the door.i nave also some clips that hang it,but it isn't enough. Someone have an idea to tell me how can i do to stop it?
wizard124
Post by wizard124 »
81SPIDERMATT wrote:mine comes off when you roll up the window .... i would love to know if there is some type of clip that i am missing or do i just need to pinch it a bit so it stays on better .... Matt
I used thin self-stick foam sheets (available at Michaels Crafts stores). Cut thin strips and stick these along the window gap edge. This gives the trim pieces more to bite onto. :D
laura79
Post by laura79 »
Thank you very much to all of you...i think that your advices will be very helpful!thank you you are great...
