Heat shield under shifter and center console
- joelittel
Does anyone know where to get one of these, or what I could use in it's place? Mine has seen better days and as long as it's out of the car I would like to replace it.
Re: Heat shield under shifter and center console
this might help
http://fiatspider.weebly.com/my-fiat-sp ... l-diy-seal
http://www.autoricambi.us/product/TR3-4 ... fter-Boot/
- joelittel
Thanks for the reply, but it's not that foam piece I'm looking to replace. I'm talking about the one that's stiff on one side, like it's been fiberglassed, and fluffy like fiberglass home insulation on the other. My best guess is that it's a sound deadening and heat shielding material. It does cover the same area of the center console as the one you linked above though.
Years ago I was fortunate to have a boat manufacturing place down the road. When I needed something similar, I went there and ended up with a chunk of sound deadening/insulating material they used around the engine box.
Snoop around and see if there is anything similar in your area?
Chris
Chris
Insolite, or similar closed cell foam
- joelittel
Thanks guys, I'll look into both those options.
- toplessexpat
- Your car is a: 1976 Spider 1800
I used the same material i redid the carpet underlay in. Keeps sounds and heat out just fine.
A
A
- 124JOE
you could go to the scrap yard and pull out some carpet pad from any car and use rubber undercoat on it
then cut to shape
hope this helps.joe
then cut to shape
hope this helps.joe
I would just go with industry standard Dynamat whenever possible.
- bradartigue
To make the original material, first catch and then skin 200 cats...
1970 124 Spider
http://www.artigue.com/fiat
- joelittel
these are all great ideas, thanks guys
