wiper relay
veloce
wiper relay
Post by veloce »
1981 spider wiper relay click all time and wipers move about 6"they stop 6"more inches they stop and so on.
PLEASE HELP
azruss
Re: wiper relay
Post by azruss »
Pull the gearbox cover on the wiper motor. There is a return switch in there that activates by moving up on a small platform as the gear reaches the stop position. Sounds like that switch may be stuck.
Re: wiper relay
The wiper switch n the column has 2 positions the first is delay and uses the relay, the second is continuous and does not use a relay. You could have too much friction in the mechanical linkage of the wiper assembly which is very common. Have you disassembled the wiper linkage freed, cleaned and lubricated them. Needs to be done periodically.
mikeb1223
Re: wiper relay
Post by mikeb1223 »
I have a question on that Lol, how do you remove the cowl to access the wiper motor and linkage? Is there a thread that explains it I have searched but I can't find it
nalle
Your car is a: Spider 2000 1982
Re: wiper relay
Post by nalle »
There are 4-5 screws in front of "the wiper plate" just open them and pull the plate away.
Becareful thet you do not make any marks on your paint.
Spider 2000, 1982
Ex Jaguar X-type 2.2, 2009
Jaguar XE 2.0 AWD
"A single fact can spoil a good argument"
4uall
Re: wiper relay
Post by 4uall »
mikeb1223
Re: wiper relay
Post by mikeb1223 »
Holy hell I'm blind I didn't see this screws... Lmao I thought it was like tack welded in or something
4uall
Re: wiper relay
Post by 4uall »
divace73
Re: wiper relay
Post by divace73 »
thought I'd post just quickly here as it is somewhat related. I just installed a bypass relay to supply 12V (from the Starter motor lug which goes straight to the battery and alternator (via fuse of course)) to the input switch of the speed selector on the dash. Massive improvement, however the rest of the system need to be lubricated and run smoothly. He initially also had some weird operating issues which I figured was an incorrect wired motor.
Cheers David
see my >>You tube channel<<
Re: wiper relay
I agree adding a wiper relay similar to what you have is a great improvement.
tartan18
Re: wiper relay
Post by tartan18 »
What kind of lubricant is best for the windshield wiper linkage? It rains a lot here in Western Oregon so I use my wipers a lot. WD40 washes off quickly and I have also not been happy with white lithium grease as it also washes off within a few months. How about marine grease (waterproof) ? Your recommendations please. :)
+1 on adding a relay.
Jim MacKenzie
1975 Fiat Spider
divace73
Re: wiper relay
Post by divace73 »
tartan18 wrote:What kind of lubricant is best for the windshield wiper linkage? It rains a lot here in Western Oregon so I use my wipers a lot. WD40 washes off quickly and I have also not been happy with white lithium grease as it also washes off within a few months. How about marine grease (waterproof) ? Your recommendations please. :)
I've been told that copper grease works well and the other I was thinking of was that plumbers grease you get when greasing up water taps (don't know if you guys call the faucets??) I think it may be Lithium??
Does anybody know what Fiat recommended (if they made a recommendation?)
Cheers David
bradartigue
Re: wiper relay
Post by bradartigue »
Anything is better than the nothing that is usually on the rack. WD-40 is a joke of a lubricant...more of a water dispersant (WD!) I usually use a ceramic based grease (used on R/C gearboxes) as it tends to hold up...probably the same as marine grease.
DieselSpider
Re: wiper relay
Post by DieselSpider »
Use grease specific for electrical use as it will not harden and turn into an insulator. Be mindful that some non-electrical grease will have a pressure additive that will not react well to aluminum or copper and promote a corrosive reaction.
Re: wiper relay
I like to drill the out shaft housing with an 1/8 to form a lubricating hole. The hole is drilled so when on the car the hole is pointing up. Each spring when I get the car ready I remove the wiper arms the nuts holding the black dress pieces and the dress pieces and put a couple drops of 30 weight non detergent oil in. Then reassemble.
As for the grease I use Penns oil synthetic wheel bearing grease. It does not jell in the cold.
Hope this helps
