Un-connected Bosch FI Pressure Sensor
mighty7
Your car is a: 1985 Pininfarina Spider Azzura
Post by mighty7 »
Does anyone know why I have a Bosch fuel injection pressure sensor on my 1985 Pininfarina Spider Azzura that is not even hooked up? Should it be hooked up? Could it be hooked up? Is there even a connector on the FI cable harness for it? Shouldn’t the computer use information from that sensor to adjust the mixture when I drive into the mountains or on a cold day, etc?
Thanks, Scott
Re: Un-connected Bosch FI Pressure Sensor
hmmmmmmm.... my 80 FI doesn't have one of these.
GeorgeT
Post by GeorgeT »
I believe that is an atmospheric pressure sensor. Not sure how it is used; my '82 did not have this.
Tobi
Post by Tobi »
That is an altitude sensor for 84 and 85 spiders. Could be the hook up was optional. I think in some Lancias they came in a bag in the glove box. That would make sense to have that installed in northern California.
mighty7
Post by mighty7 »
Does that mean my fuel injection harness is not from my 1985 since there are no harness points to go to it?
ga.spyder
Post by ga.spyder »
I am pretty sure that has nothing to do with your fuel injection.
Craig Nelson
Fling It Around Turns !
majicwrench
Post by majicwrench »
That is indeed a altitude sensor. I would let sleeping dogs lie, assuming car runs well now.
Keith
ga.spyder
Post by ga.spyder »
Keith,what is its purpose,and is it connected to the F.I. system? Just curious,I have never seen one.
Craig Nelson
BEEK
Your car is a: 1975 Spider
Post by BEEK »
on the 83 and later spiders the injection system had the altitude sensors installed. if your harness does not have a place to connect it, then i agree that someone has changed your harness. your car will run just fine without it
75 spider
son has 78 spider
ORFORD2004
Post by ORFORD2004 »
None on my 83
mighty7
Post by mighty7 »
so anyone know where to get a new FI harness for an '85?
FiatMac
Post by FiatMac »
ga.spyder wrote:Keith,what is its purpose,and is it connected to the F.I. system? Just curious,I have never seen one.
Craig,
The altitude sensor corrects the fuel injection system for the loss in air density with altitude. The L-Jetronic air flow meter measures air volume entering the system. However, a mass flow is required to get proper air fuel ratio (Air Fuel Ratio = Mass of Fuel/Mass of Air) so air density is needed. The electronics in the ECU are set up with fixed density. This has little effect unless you have large swings in altitude. The '83 and higher ECU uses the altitude sensor to make the correction. Air pressure decreases with altitude which results in a density decrease. The sensor output varies with atmospheric pressure. The output signal is fed to the ECU to adjust the fixed density in the hardware.
When the engine is running where the O2 sensor is correcting the mixture, the lack of an altitude/barometric pressure correction is not a problem. The issues will be at idle and wide open throttle. Without the correction, the system will run rich at high altitude or low barometric pressure since less air mass is supplied at the measured air volume. Since running rich at wide open throttle is on the safe side, and may even be desirable from a power standpoint, wide open throttle is not a particular issue. There likely would be some rough idle issues.
The sensor probably was added to address the idle issues and emissions requirements.
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
majicwrench
Good explanation.
ga.spyder
Post by ga.spyder »
Thanks,Stan
Craig Nelson
