TEMPLATE
fiat218
TEMPLATE
Post by fiat218 »
was thers some one who had a photo of a template? as to where he mirror on the driver side would sit
i have the mounts under the inside of the door but i would never be able to pin pot them from the top to get the mirror in the right line up with the pre mounted nuts inside the door
can some one help me get a template
thanks
1980 2000
Re: TEMPLATE
Could you get a drill in there and drill small pilot holes up from the inside to show the locations?
fiat218
Re: TEMPLATE
Post by fiat218 »
RRoller123 wrote:Could you get a drill in there and drill small pilot holes up from the inside to show the locations?
no, i don't see how i could. possible if i remove the whole inside or the track and glass, and that ain't going to happen
azruss
Re: TEMPLATE
Post by azruss »
in the gray area below the header on this page is a section called "view your posts". if you click on that, you will find a blog titled "side mirror" that you posted on 6/16/12. I posted my pix there.
fiat218
Re: TEMPLATE
Post by fiat218 »
azruss wrote:in the gray area below the header on this page is a section called "view your posts". if you click on that, you will find a blog titled "side mirror" that you posted on 6/16/12. I posted my pix there.
ok thanks :)
