1981 Fiat Spider 2000 - What am I doing!? LOL!!
Re: 1981 Fiat Spider 2000 - What am I doing!? LOL!!
Ohhhhhh. Did some of them not come with them? Or did your's rot out? Have you thought about just making a set? I'd imagine bungie chords would work. Or you could go to home depot or a supplier to get giant springs. I can measure these for you.
- 124JOE
no my 78 dosent have the holes and hooks for them
they gave me a rod witha spring,that i pull down and the lid stands on it.
and the spring pulls the rod leg back tward the center for closing the lid.joe
i guess im good
i guess im good
- Kingme2
- Your car is a: 1980 124 Spider
124JOE wrote:sizes i dont knowjimmycakes401 wrote:Any hose masters out there? I know one of them is 8mm. LOL!
2/3/4 appear to be vacume hoses.
5/7 is brake hose
6 is a fuel line
i think .joe
awesome... I've wanted to replace my Uglies with something nicer, now I have a start on type (just have to measure for sizes...unless someone knows?)
Due to recent budget cuts and the rising cost of electricity, gas, and oil, we have decided to turn off the light at the end of the tunnel. We apologize for any inconvenience.
1981 Fiat Spider, all black... "Corvino", italian for the Raven
- 124JOE
#6 is 8mm-5/16 fuel line
#5 #7 are hydrolic line 8mm i think.joe
Oops! You're right. 6 is fuel line. I was thinking it was the other hydraulic hose.
Yesterday I sanded down the trunk compartment primed it and then used seam sealer on open joints. Obviously left the drain holes and various screw holes. Today I plan on priming over the sealer and using fiberglass fill for the two large plumbers putty gaps. Next up, I have to make templates because I don't have ANY of the original cards.
Why are there wires in my doors if I don't have power windows?
- Danq
It is easier to make one style of wiring harness that has the wiring for every option than to make a dozen different one and get the proper one in the correct car on the assembly line. There is wiring for radio in the factory harness including power antenna but a radio was a dealer installed option. Wire is cheap compared to the labor to put it in.
Dan
1981 spider 2000
1981 spider 2000
Okay. Cool. That's what I was hoping. Guess it makes it easier to install power windows if I want later. I've always been a fan of crank.
Yesterday I coated my gas tank with rust reform. Tonight I will top coat it. I need to figure out how to hang it up so I can paint the whole thing at once. Or I'll use a nail board. For more info about the build visit http://fiatspider.weebly.com
Just put up some new info on my blog. http://fiatspider.weebly.com
Put the fuel pump in last night. Need to put in the return line. After that's complete I need to do all the welding on the back end. After that I'll fill her up with some gas and see how she runs.
I'm replacing my timing belt and decided to order a new tensioner bearing. I needed to pick up some rubber grommets for my radiator. They seem to be missing. I'm trying to think of any small pieces I may need that I can add to the order. Not a lot of money rattling around, but I want to grab any small bits I can use later. Any suggestions? Check my blog.
