OK, I am starting an new thread to discuss intake manifolds for fuel injected engines.
Clark,
How far upstream did you open up the stock manifold beyond the interface with the head? I don't have an inside micometer so was unable to measure much beyound face. The runner takes a bend rather quickly, and I don't know how far the face runner diameter extends.
Also could you post your results to this thread so we can keep things together?
Thanks!
Fuel Injection Manifolds
- FiatMac
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
83 parts car
- FiatMac
Re: Fuel Injection Manifolds
Clark,
Hope you don't mind. I was able to get a link to your data and include it in this post.
Clark's Data http://www.flickr.com/photos/65984720@N07/6009827274/
Stan McConnell
83 parts car
83 parts car
- Your car is a: 1970 128
Hi FiatMac,
I have played around with this a little.
Pictures and a bit of a story here;
http://www.turbo124.com/forum/viewtopic.php?f=11&t=7405
It is the boring story of my very long turbo spider build.
Have a look and let me know if you have any specific questions.
I still have the extra intake that is mentioned in the thread.
Jordan
Jordan
- FiatMac
Thanks for the comparison drawing and info on purchase. If I go this route I need to decide on bare manifold vs. with TB and injectors. What is the flow rate on the Croma injectors?
SteveC wrote:
"Here's a little comparison between some stock Fiat manifolding, personally I like the Croma manifold, and yes it fits a RHD spyder / coupe body... "
Since I am in the US, my spider is LHD. Looks like the Croma manifold might interfere with the Brake booster and/or the master cylinder??? I have been toying with a design modification to install dual reverse mount master cylinders under the scuttle/dash using Tilton or Willwood master cylinders and cross bar for brake bias. That would clear up some space under the hood.
Stan McConnell
83 parts car
83 parts car
- FiatMac
I see that Kbe00 already answered my question about the Croma interference with the brake booster in the Megasquirt thread.
Stan McConnell
83 parts car
83 parts car
- kbee00
- Your car is a: 1972 Spider
I would also like to know the flow rate of the Croma injectors....FiatMac wrote:Thanks for the comparison drawing and info on purchase. If I go this route I need to decide on bare manifold vs. with TB and injectors. What is the flow rate on the Croma injectors?
If you decide to go the dual master route - I would like to learn along with you. I had toyed with this idea too, but not sure if the extra effort is worth it on a street car. All my race cars of course had dual masters with a bias bar but that was almost a requirement at that level.
The biggest issue I see is room under the dash for the masters.
Anyway - I will follow along and if I can help in any way, let me know. My car is being torned down completely for a rebuild so it won't be until the winter when I reassemble it anyway. I have room now that the dash is completely out of the car - so if you need measurements, etc. let me know.
1980 Strada (crushed)
1982 Strada (parts for the 1980 then crushed)
1966 MGB (E-Prod race car - sold)
1968 MGB (Targa Newfoundland - totalled)
1979 Spider (current vintage restoration)
1972 Spider daily driver
- FiatMac
Kbee00,
Thanks for the offer. I have a parts car that is mostly disassembled that I will used to test fit things. I am looking at modifying the existing brake/clutch pedal assembly to mount the master cylinders. Looks doable right now but I have not started a prototype. My biggest concern is access for maintenance.
Stan McConnell
83 parts car
83 parts car
- Your car is a: 1975 Spider
off thread topic: my scorpion build has dual master cylinders, when i was using fiat brakes i used a 13/16 ft and a 3/4 rear m/c, now im using mitsubishi 3000gt brakes.kbee00 wrote:
son has 78 spider
son has 78 spider
